[Fixed] Firefox Problem with CNET downloads
- [Fixed] Firefox Problem with CNET downloads
15-05-2009 1:16 PM
As an example going to this site http://download.cnet.com/Adblock/3000-11745_4-10461863.html locks up Firefox with the bottom left of the screen showing this. Note I have no problem with IE8 (this happens when using Vista and Windows 7)
8 REPLIES 8
Re: Firefox Problem with CNET downloads
15-05-2009 1:24 PM
works fine for me FF 3, Mac OS X.
15-05-2009 1:33 PM
Tried disabling all the addons and still the same problem
15-05-2009 1:49 PM
working ok in FF3 under xp too...
15-05-2009 1:53 PM
I can't reproduce your problem either, Jim.
15-05-2009 2:18 PM
Uninstalled Firefox from the Windows 7 partition removing all records then reinstalled and works fine.
It must be something in my settings in the Vista partition which I ported over to the Windows 7 installation.
Now for some digging - thanks for the help
15-05-2009 2:43 PM
Why were you looking at Adblock?
15-05-2009 3:06 PM
Because it seemed to work better than adblock plus
Having said that I am using Adblock Plus on the windows 7 installation to compare
15-05-2009 4:07 PM
Problem solved - I don't know which bit did it but I used MozBackup to get all the important parts back - except for General Settings as something in there was messing it up
