[Fixed] Firefox Problem with CNET downloads
Oldjim
Resting Legend
Fixes: 63
As an example going to this site http://download.cnet.com/Adblock/3000-11745_4-10461863.html locks up Firefox with the bottom left of the screen showing this. Note I have no problem with IE8 (this happens when using Vista and Windows 7)
8 REPLIES 8
Fixes: 1,483
Re: Firefox Problem with CNET downloads
works fine for me FF 3, Mac OS X.
Oldjim
Resting Legend
Fixes: 63
Tried disabling all the addons and still the same problem
Fixes: 1,483
working ok in FF3 under xp too...
James
I can't reproduce your problem either, Jim.
Oldjim
Resting Legend
Fixes: 63
Uninstalled Firefox from the Windows 7 partition removing all records then reinstalled and works fine.
It must be something in my settings in the Vista partition which I ported over to the Windows 7 installation.
Now for some digging - thanks for the help
jelv
Fixes: 10
Why were you looking at Adblock?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Oldjim
Resting Legend
Fixes: 63
Because it seemed to work better than adblock plus
Having said that I am using Adblock Plus on the windows 7 installation to compare
Oldjim
Resting Legend
Fixes: 63
Problem solved - I don't know which bit did it but I used MozBackup to get all the important parts  back - except for General Settings as something in there was messing it up
