Fix for www.nationwide.co.uk slowness on Linux
ejs
Aspiring Hero
Fixes: 25
In case anyone else has ever wondered why www.nationwide.co.uk can be stupidly slow to load on Linux, with images peeling down one line of pixels at a time, the problem is due to TCP Window Scaling. Somehow the TCP window size utterly fails to scale, and data ends up trickling in 115 bytes at a time, each one having to be acknowledged before the next will be sent.
I thought the problem may have gone away on its own last time I checked their website, but just now I saw the 4MB 2013 annual report pdf downloading at an entire 1.76KB/s - dialup speed!
In order to download the 4MB pdf in somewhat less than 37 minutes, I disabled TCP window scaling (as root):
# echo 0 > /proc/sys/net/ipv4/tcp_window_scaling
I turned it back on afterwards:
# echo 1 > /proc/sys/net/ipv4/tcp_window_scaling
9 REPLIES 9
ejs
Aspiring Hero
Fixes: 25
Re: Fix for www.nationwide.co.uk slowness on Linux
Further investigation: www.nationwide.co.uk has 2 IP addresses, 155.131.31.10 works fine, 155.131.127.10 is the bad one.
w23
Fixes: 4
Hmmm, Someone's systems need updating.
(not yours, theirs!).
Call me 'w23'
HairyMcbiker
All Star
Fixes: 21
I NEVER go to the home screen, it used/does take ages to load, I jump to the log out screen then log in again this has never given me any speed issues.
Just checked the 2 ip's and the 2nd crawled down the screen the 1st was normal.
Have you posted the problem to the webmaster?
Fixes: 393
Always wondered why sometimes it's ok and sometimes it's slow Roll_eyes
HairyMcbiker
All Star
Fixes: 21
Quick fix, put the 1st ip in your hosts file as nationwide.co.uk
Fixes: 393
Yep, I was going to do that when I get home.
ejs
Aspiring Hero
Fixes: 25
All I could find on the website was the feedback form, which warns you not to submit any personal information and that you won't get a reply.
I think this is adequate to disable tcp window scaling for a particular IP:
iptables -t mangle -A OUTPUT -m tcp -p tcp --syn -d 155.131.127.10 -j TCPOPTSTRIP --strip-options wscale
Edit: optimized iptables rule by adding --syn
kjpetrie
Fixes: 5
Can't say I've ever noticed a problem:
$ cat /proc/sys/net/ipv4/tcp_window_scaling
1
Must be more to it than that.
ejs
Aspiring Hero
Fixes: 25
Sometime between the original post and now, their website only resolves to the good IP address.
