Fix for www.nationwide.co.uk slowness on Linux
- Re: Fix for www.nationwide.co.uk slowness on Linux
22-06-2013 6:49 PM
I thought the problem may have gone away on its own last time I checked their website, but just now I saw the 4MB 2013 annual report pdf downloading at an entire 1.76KB/s - dialup speed!
In order to download the 4MB pdf in somewhat less than 37 minutes, I disabled TCP window scaling (as root):
# echo 0 > /proc/sys/net/ipv4/tcp_window_scaling
I turned it back on afterwards:
# echo 1 > /proc/sys/net/ipv4/tcp_window_scaling
23-06-2013 8:29 PM
23-06-2013 8:31 PM
(not yours, theirs!).
24-06-2013 11:41 AM
Just checked the 2 ip's and the 2nd crawled down the screen the 1st was normal.
Have you posted the problem to the webmaster?
24-06-2013 11:45 AM
Always wondered why sometimes it's ok and sometimes it's slow
Quote Further investigation: www.nationwide.co.uk has 2 IP addresses, 155.131.31.10 works fine, 155.131.127.10 is the bad one.
24-06-2013 11:50 AM
24-06-2013 12:01 PM
24-06-2013 6:47 PM
I think this is adequate to disable tcp window scaling for a particular IP:
iptables -t mangle -A OUTPUT -m tcp -p tcp --syn -d 155.131.127.10 -j TCPOPTSTRIP --strip-options wscale
Edit: optimized iptables rule by adding --syn
25-08-2013 12:36 PM
$ cat /proc/sys/net/ipv4/tcp_window_scaling
1
Must be more to it than that.
25-08-2013 1:00 PM
