FitBit Aria 2 Not Connecting to PlusNet
Flann1gan
Following the instructions explicitly, my FitBit Aria 2 device will not connect to the PlusNet Wi-Fi.
  • The mobile app connects to the device
  • The device can see the Router
  • Wi-Fi Password has been input correctly
  • The Device times out from connecting to WiFi
I have tried all the trouble shooting steps including:
  • Removing the batteries
  • Removing the app
  • Connect to another WiFi (mobile - which worked as it should)
FitBit's own help service have asked if the PlusNet router conforms to the follow standard:
  • 802.11b/g/n frequency setting
  • WEP / WPA / WPA2 personal security Automatic (DHCP) IP setup (static IP configurations are not supported)
  • Both the network name and password must be no more than 32 characters long
These questions have been asked on this forum but not resolved
https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Problems-connecting-Fitbit-Ionic-to-Pl...
and
https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Connecting-a-FitBit-Aria-weight-scale-...
1 REPLY 1
Fixes: 1,467
Re: FitBit Aria 2 Not Connecting to PlusNet
Assuming it's a Hub One, you could try splitting the 2.4Ghz and 5Ghz frequencies and seeing if that helps.
I had a similar experience with and echo that never got resolved until I got a different router, sadly.
