First project with my Pi Zero
- First project with my Pi Zero
13-01-2016 6:06 PM
Installed a i2c OLED display and a CM108 audio card. (& wifi card)
Used the Magpi article oled pyradio as a base. (July issue if you want to read it). Don't do what I did and try Raspberiran lite, I had to install a load of extra files to get it working.
The i2c stuff was simple enough, same as the pi B.
The CM108 was a bit more of a pita but found an article from Adafruit (HERE) on how to enable it.
Now just got to find a smaller usb hub and box it up.
Simple Mpd driven internet radio, controllable from any Mpc enabled device. Might use it to replace my bedroom pi running Kodi as an internet player. Since it is on 24/7 the lower power will be good (maybe 2W vs 8W ;D)
Thought I might try getting another zero but they are still in short supply.
Re: First project with my Pi Zero
15-01-2016 1:21 AM
15-01-2016 7:29 AM
http://swag.raspberrypi.org/collections/pi-zero/products/pi-zero
They're just out of stock due to extremely high demand...
15-01-2016 9:31 AM
They have basically been OOS since then. Massive demand, who would have thought it eh?
15-01-2016 9:34 AM
Quote from: Hairy I was lucky I bought the MagPi mag at Tesco when it first came out.
If you found that issue in a Tesco store you really should have bought a lottery ticket at the same time, luck like that is rare.
15-01-2016 10:04 AM
15-01-2016 10:07 AM
I read about the zero at El Reg and saw that the MagPi mag had a free one on the cover, so thought I would try the local shops, Tesco was where I started.
I did go back after I saw them being sold on ebay for £30+, but of course there were none left.
To add insult to injury ... I had a £1 voucher for Tesco and got staff discount (wife works there) so I got the mag for £4.40! Cheaper than I could have gotten it delivered.
15-01-2016 10:20 AM
Quote from: Hairy I got the mag for £4.40!
Maybe I'll eventually manage to get a Pi Zero, until then I'm not talking to you!
[Edit] OK, I'll stop sulking now, I expect to have to wait quite a while to get hold of one (or two) of these little beauties.
15-01-2016 10:24 AM
15-01-2016 10:30 AM
I bought it from ebay, an auction that said it was a particular chip set the pi could use, when it got it it had a different chip that didn't work, so I got a refund. The latest kernel/raspberrian works with it now so all is good.
Got a smaller one coming from China maybe next month it will arrive.
15-01-2016 10:44 AM
Quote from: Hairy
Indeed. You would have thought they'd learnt from the launch of the original Pi, and produced more than 30k Zeros to begin with
15-01-2016 10:52 AM
26-01-2016 4:07 PM
https://shop.pimoroni.com/products/raspberry-pi-zero
Looks like they just got some Pi Zero's in, but only the full starter kit is left in stock.
27-01-2016 3:27 PM
27-01-2016 3:32 PM
I checked it again at about half 6 and they'd all gone
I only knew about it because I had clicked the Notify Me button and provided my email about a month ago.
