Firefox was ok now keeps crashing
- Re: Firefox was ok now keeps crashing
10-11-2011 10:08 PM
Have used Firefox on my mini-laptop for ages but since a couple of days ago it comes up with a crash message (can still use Firefox on my desktop with no problems).
Have completely removed it and reloaded it a few times but problem still persists.
Any ideas folks?
(Meanwhile using Internet Explorer for web access).
Any ideas folks?
6 REPLIES 6
10-11-2011 10:13 PM
What version are you using and have you updated it recently?
10-11-2011 10:26 PM
I have FF 8.0 on my win 7 netbook, that works OK, SWMBO has it on a XP netbook also OK
11-11-2011 12:49 PM
I use XP on my laptop and was using Firefox v 7.0
Whilst working on my desktop I just noticed upgrade to v 8.0 so downloaded this for my desktop (runs Windows 7)
Still puzzled why when I have deleted the previous Firefox installation then downloaded it again (which vesion should it be I wonder - 8.0?) why I got that error message.
Hey ho will try another download later.
11-11-2011 10:26 PM
Could it be the Firefox user profile which has boobed up?
Try opening Firefox in the Profile Manager mode and create a new profile and test that.
http://kb.mozillazine.org/Profile_manager
14-11-2011 6:34 PM
As TheJudge says, may be a problem with your FireFox profile. I've had a few problems with the FFprofile for a few updates with FF and had to wipe the profile and start from scratch
14-11-2011 9:47 PM
Hello folks - thanks for your interest and offers of advice.
I have just tried downloading Firefox 2011 version - and bingo I am up and running again!
Don't know what was happening but am a happy budgie again. Cheers to all.
