Firefox update 2.0.0.8 - problem with Java Applets
Have recently downloaded the update (as above) and there is a bug - Java applets are not working correctly.  I have updated to Java 6 (I am using Vista Home Basic) and have Java enabled in 'Tools' but still I cannot play my online jigsaw.  I did a system restore and everything was OK again but unfortunately, although I changed the automatic updates to 'warn me about updates' it has downloaded the update yet again. Until it is fixed, I don't want to download the update at all. I know that it is not my computer because we have another laptop and exactly the same thing happened with this one today.
Does anyone have any ideas about this?  Particularly about blocking updates until the problem is sorted?
kevgti
Re: Firefox update 2.0.0.8 - problem with Java Applets
Haven't encountered any problems yet with Firefox 2.0.0.8 and Java 1.6.0_03
Yes, I had disabled automatic updates in Firefox 'Tools' after the incident but it still keeps popping up to try to update (it has just done it now - it's a pain). Hopefully Mozilla will come up with a fix sometime soon.
