Firefox spelling check
- Re: Firefox spelling check
26-11-2008 3:13 PM
I though I understood Firefox and been using it since version 0.99
I seem to have lost the abilty to spell check as you type in forums like this .where mispelled words had the red undeline .
I had a problem a while ago, uninstalled and reinstalled afresh including clearing all files - and I couldn't use the spell check facility.
I've installed a fresh edition on a Vista laptop and it works on that .
26-11-2008 3:20 PM
Haven't had any luck in tracking it down either
26-11-2008 3:27 PM
It seems to have lost my British dictionary so I had to do a right click in here select 'add dictionary'.
Now working again, not sure why it was lost though.
HTH
26-11-2008 3:48 PM
That was it - many thanks - I right clicked and added the British dictionary.
No idea why it stopped working earlier though
cheers
Mal
26-11-2008 3:50 PM
Quote from: mal0z .where mispelled words had the red undeline .
Is that wot the red underline means.
Joking aside, it often does that when you update. as adiewoo said you just have to add the English dictionary back in.
26-11-2008 5:48 PM
26-11-2008 7:21 PM
- Windows XP SP3 was ok
- Mac OS X broke
- Windows Server 2003 R2 SP2 broke.
Haven't checked my Linux box yet..
26-11-2008 8:03 PM
Quote from: pierre_pierre I have XPSP3 firefox 3.04 and it spells color correctly as colour didnt have to reinstall when it uodated from 3.03 to 3.04
Install the British English language option - right click etc
26-11-2008 8:05 PM
26-11-2008 8:07 PM
