Firefox + default Google search on Plusnet.
nbk
Bit of a strange one...has anything broken at plusnet with regards to IP locations? Smiley
Google search from the firefox search bar uses IP locations to send you to the current google homepage and for a long time this has worked and sent me to google.co.uk
However lately it hasnt got the location at all and keeps sending me to the US (.com) page which while searching normally isnt such an issue, when wanting more local things like shopping it's an issue since it sends you to US results for US shoppings sites.
At the moment, through a lot of hopping, I'm on an IP that correctly sends me to .co.uk for search results and I've come across a couple of others gateway hopping that also worked correctly but for the most part on Plusnet IPs (and incidentally on my fathers BT connection) we incorrectly get sent to the google.com site.
At the moment google is reporting my location (at the bottom of search results) as "Greater London - From your Internet address" however when i get directed to .com the location is "unknown".
This has only started occuring recently...and yes it got a bit annoying and forced me to gateway hop a lot to find something that works correctly Smiley
Chrome seemed to work fine however.
9 REPLIES 9
jelv
Fixes: 10
Re: Firefox + default Google search on Plusnet.
See http://community.plus.net/forum/index.php/topic,130918.0
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
nbk
mmm i know about that thread however on all the IPs i tried I checked the geolocation sites and all reported to be plusnet in the UK
Oldjim
Resting Legend
Fixes: 63
try fixing it as described here https://support.google.com/websearch/answer/179386?hl=en
I changed mine to england so Google Maps works properly
nbk
thanks oldjim but that doesnt resolve the issue for the default google search in firefox bar...i already had the location set to my hometown since on plus it's detected as london Smiley
jelv
Fixes: 10
In Firefox options, Search what do you have designated as your Default Search Engine? Mine is Google UK
nbk
Quote from: jelv
there isnt actually anything like that in firefox 39 as far as i know...and it's all based on the IP google sees you from on the firefox search bar
jelv
Fixes: 10
I'm using Firefox 39!
Oldjim
Resting Legend
Fixes: 63
My default search option is just shown as Google (under Tools Options Search) but then again I don't use it in the location bar
Just tried it and it goes to Google UK
Anotherone
Champion
Fixes: 21
Try clearing all the caches as well.
