Firefox Tabs
Fixes: 174
Firefox Tabs
I use Firefox 2.0.0.9
Does anyone know how to set Firefox to open the home page when pressing ctrl 'T' for a new tab instead of a blank page.
IE7 does this if the right box is ticked.
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Fixes: 10
Re: Firefox Tabs
I just middle click the home page icon.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 174
Re: Firefox Tabs
Quote from: jelv
jelv....you are a genius.
I didn't know about that.
Thanks very much Smiley
Edit: This is another case of read the ******* manual.
Just read about it in the Help file Embarrassed
Fixes: 10
Re: Firefox Tabs
Alternatively install the Tabbrowser Preferences extension
Re: Firefox Tabs
I use the keyboard shortcut (Ctrl-T for new tab, then Alt-home for the home page).
Fixes: 174
Re: Firefox Tabs
Thanks guys
I obviously couldn't see the wood for the trees  Embarrassed
Fixes: 10
Re: Firefox Tabs
Quote from: orbrey
With tabbed browser preferences you can make Ctrl-T load your home page.
Darren
Re: Firefox Tabs
Or you could try <a href="https://addons.mozilla.org/en-US/firefox/addon/4810"> Speed Dial</a> I find this very helpful.
Fixes: 103
Re: Firefox Tabs
Quote from: jelv
Yep, that's what I use. It can be downloaded from here.
This is the setting you're looking for:
Fixes: 174
Re: Firefox Tabs
The Tabbed Browser add-on I like....thanks Grin
minkey
Re: Firefox Tabs
I have installed Tabbed Browser add-on and I have a question about it. When you select a recently typed webpage (from the drop-down) I now have to hit the Green 'Go' Arrow button and I am sure it didn't do that before. Is there a way to auto 'go' to the web page I select from the drop down?
Jeff
Fixes: 103
Re: Firefox Tabs
Hi Jeff,
Not too sure about this one as I've the extension installed here and at home. If I disable it though, I still have to click go before I'm able to load anything from the address bar history.
I'm guessing it's a known bug. Not to sure if the add-on is still in development or has been shelved though TBH.
Another problem I noticed is after you upgrade Firefox. It forgets the setting I mentioned above and reverts back to each tab opening with a blank page. You have to go back into the config to change it.
I wonder if Firefox 3 will accommodate this functionality without the need for an add-on?
Re: Firefox Tabs
Quote from: Bob
...reverts back...
Aaargh - Double negatives!!!
It either reverts, or goes back - not both, since they are both the same thing. Wink
</Pedant>[me=James_H]waits for the flame war when he makes a bad grammatical error![sic][/me]
Fixes: 174
Re: Firefox Tabs
NOOOOOO!!!
Don't start me off with double negatives like 'I haven't got none' Angry Angry Angry
If my daughter asked me to lend her £10 I say "I haven't got no money at all" which she takes as meaning she gets nothing and I feel better knowing I haven't lied to her. Wink
nmercer
Re: Firefox Tabs
Quote from: Strat
NOOOOOO!!!
Pluralised singles make me wince, such as 'Can I have one of those ones please'.
