Firefox Problem That Windows Cant Find A Solution To ( Again )
- Re: Firefox Problem That Windows Cant Find A Solut...
29-08-2010 10:13 PM
Re: Firefox Problem That Windows Cant Find A Solution To ( Again )
29-08-2010 10:25 PM
Just to add - that program runs plugins in a container so that if the plugin crashes it doesn't take Firefox down with it
29-08-2010 10:26 PM
29-08-2010 10:32 PM
29-08-2010 10:34 PM
Edit, Yes Oldjim I believe your correct!! Just went to speedtest.net and flash is not working at all.
29-08-2010 10:38 PM
Definitely uninstall and reinstall
The only ones I have installed are Shockwave Flash Plugin and Shockwave for Director
29-08-2010 10:39 PM
29-08-2010 10:44 PM
Edit. Found out how to uninstall at the adobe website. http://kb2.adobe.com/cps/141/tn_14157.html
30-08-2010 12:14 AM
It is doubtful that you have achieved anything.
Flash will Crash again - because it was designed that way.
30-08-2010 3:06 PM
