Firefox Issue
- Firefox Issue
- « Previous
- 1
- 2
- Next »
Re: Firefox Issue
15-09-2018 2:49 PM
@shutter wrote:
The "problem" that @Strat has come up against, is not necessarily Firefox problem,...
Agreed. windows 10 could be involved or even my Kaspersky but it's difficult to track down.
I can temporarily disable Kaspersky but Windows is a different matter.
A certain member might suggest I switch to Linux but I doubt I have sufficient time left to learn a new OS in detail.
Re: Firefox Issue
15-09-2018 2:56 PM
+1 for the suggestion to use Linux @Strat, come to the dark side, we have penguins!
Re: Firefox Issue
15-09-2018 3:06 PM - edited 15-09-2018 3:07 PM
@Darkfire wrote:
we have penguins!
@chillypenguin hasn't been on here for a while so I think I'm safe.
I've dabbled with various Linux flavours in the past but when I have problems with a simple task like connecting WiFi and driver availability, Windows wins.
Things may have moved on....
Re: Firefox Issue
15-09-2018 3:16 PM
@Strat wrote:
@Darkfire wrote:
we have penguins!
They've definitely improved but for plug and play usage, windows will lead that for a while
Just gotta let my inner fanboy out now and again
Re: Firefox Issue
15-09-2018 5:38 PM
Here is a screen-shot of Firefox on Linux.
Re: Firefox Issue
17-09-2018 10:17 AM
@Strat You could always 'refresh' firefox. Menu, Help, Troubleshoot, Refresh.
Not that it cleared my problem last time I took that route. 😉 Only thing I've noticed is that sometimes it's a bit slow loading pages. Funny enough, Plusnet's forum being the worse. But it does tend to stay connected.
Re: Firefox Issue
17-09-2018 1:54 PM
I loaded this page (https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Firefox-Issue/m-p/1571531) and it came to 221.74K. However, this was built from literally hundreds of separate HTML links, which slows it down hugely. Add into the mix piles of CSS and Javascript and it takes a decently powerful machine to load it at all.
It's a very poorly "designed" website.
Re: Firefox Issue
17-09-2018 1:58 PM
@idonno I did as you suggested plus a couple of other things.
I'm noticing a small improvement so we'll see how things go.
Re: Firefox Issue
18-09-2018 5:30 PM
Update: After a fair usage my Firefox is working much better on a number of fronts.
So thank you for your suggestions guys.
- « Previous
- 1
- 2
- Next »
