Firefox 57 no support for FireFTP
Oldjim
Resting Legend
Fixes: 63
As I see it I have two options
Change to Waterfox and keep on using it
Don't do FTP access via the browser
The only non browser solution I have experience with is https://filezilla-project.org/ and I found it a bit clunky
Yonks ago I tried using Windows Explorer and gave it up as a bad job
Thoughts and advice please as i only have a month or so before Firefox 57 hits me
12 REPLIES 12
jelv
Fixes: 10
Re: Firefox 57 no support for FireFTP
1. Have a look at http://www.coreftp.com/download.html
2. Look at the Pale Moon browser - it supports FireFTP
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Oldjim
Resting Legend
Fixes: 63
Thanks @jelv that will be worth looking at when - or just before the evil day approaches
Fortunately the two sites I look after now use Wordpress (I changed them) and that doesn't need FTP access to make changes
NorthPole
Fixes: 6
Oldjim, not sure what specific features you're seeking from an FTP program, but you could take a look at WinSCP. I switched to it from FileZilla some time back and much prefer it.
Oldjim
Resting Legend
Fixes: 63
basically I want a simple one as the ftp usage will be minimal in future
I will check out the various options
VileReynard
Fixes: 20
Or FileZilla https://www.techrepublic.com/blog/five-apps/five-solid-ftp-clients-that-also-happen-to-be-free/
bobpullen
Fixes: 316
I tend to use WinSCP these days. Did rely on FireFTP but for unrelated reasons switched to Chrome as my go to browser, so had to plump for an alternative.
NorthPole
Fixes: 6
@VileReynard wrote:
Or FileZilla
But the OP said he didn't much care for FileZilla.
jelv
Fixes: 10
Plusnet are often criticised for not reading all the previous entries on a fault/ticket. And then we see the same on here - people posting replies without reading the whole topic (and it's not a very long topic either!).
VileReynard
Fixes: 20
Sorry - but then I would use a standard CLI program such as FTP. Thumbs_Up
Fixes: 1,483
But we also don’t know when OJ last used FileZilla and for someone to state using that as a preference might indicate it has improved. (It hasn’t)
I use WinSCP on windows and Transmit on Mac.
Oldjim
Resting Legend
Fixes: 63
WinSCP just worked so I am using it
Strat
Fixes: 565
Thanks @Oldjim, I'll try that as I was annoyed at the failure of FireFTP as a result of this Firefox update.
