Firefox 52 has blown it
- Re: Firefox 52 has blown it
08-03-2017 2:38 PM - edited 08-03-2017 2:41 PM
http://www.theregister.co.uk/2017/03/08/firefox_52/
The Mozilla Foundation has has given the world the fifty-second version of the Firefox browser, complete with some significant changes.
Most notable is the eviction of plug-ins. The browser will now only run Flash. Anything else reliant on the Netscape Plugin API (NPAPI) is now verboten. Which means Silverlight, Java and Acrobat are gone, daddy, gone.
To ease the passing of plugins, Firefox has added support for the WebAssembly client-side scripting environment. Mozilla says WebAssembly “brings near-native performance to Web-based games, apps, and software libraries without the use of plugins.”
The second big change is the addition of significant warnings when Firefox visits web sites that don't run HTTPS.
So how do you open a pdf file in the browser and what about all the little websites which aren't https because they have absolutely no need to
08-03-2017 2:41 PM - edited 08-03-2017 2:42 PM
All sounds good to me and with SHA-1 being broken they’ve also removed (disabled actually) support for SHA-1 signatures in digital certificates too.
08-03-2017 3:09 PM
Firefox has had its own built-in PDF viewer for quite some time now. I prefer to just download PDFs anyway.
08-03-2017 3:10 PM - edited 08-03-2017 3:11 PM
I have never used it so will wait and see
I may need to change the pdf links on one of my websites as at present they open in a new browser window
08-03-2017 3:54 PM
just tried and all it does is open it in the standalone program - so no problem
08-03-2017 4:01 PM
If you want a version of Firefox that actually works, try Pale Moon, they took Firefox, restored the original interface layout, optimised some code here and there, and resulted in a pretty decent browser that'll run many Firefox plugins which are now defunct in Firefox 52...
08-03-2017 4:02 PM
This is what you see using FF 52 when visiting an non HTTPS site using forms.
08-03-2017 4:13 PM
yes I saw that when I used my wordpress login and checking other sites it only appears on a login page
08-03-2017 4:21 PM - edited 08-03-2017 4:21 PM
yet they continue to support Flash.
that's just plain stupid.
08-03-2017 4:24 PM
agreed to an extent but if they had removed it there would have been a mass exodus of users given the number of sites which are still in the dark ages
08-03-2017 4:34 PM - edited 08-03-2017 4:37 PM
Spank me Moma spank me... meh!
08-03-2017 5:02 PM
Mine just auto updated every page i have opened no problems , same as all pdf
08-03-2017 5:17 PM
try this page as I have reported a problem https://www.plus.net/help/broadband/ in Plusnet Feedback
08-03-2017 5:23 PM
Whats up with it ?
08-03-2017 6:35 PM
@Oldjim works fine for me , all links working
