Firefox 44
- Firefox 44
Firefox 44
29-01-2016 8:29 AM
Tried start without add ons , refreshed FF still no joy . But Utube is the only page that works
They play fine in Chrome & Edge so its not my PC
Re: Firefox 44
29-01-2016 8:57 AM
Quote By late 2015, many browser vendors have either removed or announced timelines for the removal of standards based plug-in support, eliminating the ability to embed Flash, Silverlight, Java and other plug-in based technologies,
You may want to look at FF's change log to see if this is the case.
Re: Firefox 44
29-01-2016 9:30 AM
Went to ITV hub and played Flash video there too without issues
Re: Firefox 44
29-01-2016 9:34 AM
Re: Firefox 44
29-01-2016 10:26 AM
Re: Firefox 44
29-01-2016 12:00 PM
Re: Firefox 44
29-01-2016 1:34 PM
I have now removed latest Nvidea driver reverted back to older one , still no difference ?
Re: Firefox 44
30-01-2016 1:54 PM
Edge browser is Pants , Chrome is,,,,, well slow compared with FF but have to use it
Re: Firefox 44
30-01-2016 2:01 PM
https://www.waterfoxproject.org/
If, after you install, it still doesn't work can you provide some URLs for links that do not work please.
Re: Firefox 44
30-01-2016 3:10 PM
But i get no sound on any Utube video
Update i get sound on Utube Via headphones , but not speakers ?
Re: Firefox 44
30-01-2016 3:46 PM
Best to check your audio settings then, it might be a configuration issue since the sound is evidently there, either that or you've got a dodgy headphone socket which isn't unlatching when you remove the jack.
Re: Firefox 44
30-01-2016 4:32 PM
For a non techie how to I check if HTML5 has been installed on my PC?
Re: Firefox 44
30-01-2016 4:38 PM
Re: Firefox 44
30-01-2016 5:16 PM
Maybe its the Dolby setting for speakers dont like utube , as Win 10 says Dolby settings are incompatible
Re: Firefox 44
30-01-2016 5:24 PM
