Firefox 3 Beta 1
Firefox 3 Beta 1
Anyone tried the 1st Beta version of Firefox 3?
I'm using it now, but I'm beginning to think I shouldn't, since I'm missing lots of extensions I make use of regularly.
1 REPLY
holdtight
Re: Firefox 3 Beta 1
I tried FF3 for 64 bit quite a while back in its early stages and for the same reason had to uninstall it
Not tried the latest beta though so same as you Peter i might put it on a separate box
