Firefox 3.6.13 Tools/Downloads
- Firefox 3.6.13 Tools/Downloads
- « Previous
- Next »
Re: Firefox 3.6.13 Tools/Downloads
28-04-2011 4:53 PM
28-04-2011 5:00 PM
28-04-2011 7:21 PM
28-04-2011 9:12 PM
02-05-2011 5:04 PM
I cannot be as lavish as that, only 30GB HD in laptop.
Could go some way towards the ideal like this:-
/ ext3 12GB 10GB specified as minimum in texts
swap 1GB for 512MB RAM
/home ext3 17GB or as near as I can get them.
Agreed or what?? Could try 2x 14.5 GB for / & /home if worth the effort.
Regards,
02-05-2011 5:58 PM
Because it is a clean install, if you don't like the result, just do another clean install.
03-05-2011 9:49 AM
Just checked mine and my / is 28Gb but only 8.9Gb is used and that is a working system live for 5 months no 12Gb should be fine,
So when you run the installer choose CUSTOM PARTITIONING, then wipe the partition table and use the above (wipe by choosing new partition table in gparted or just delete the partitions one at a time )
03-05-2011 1:02 PM
29-05-2011 11:29 AM
No I have not done much for this, the month has sped by and some hols, agriculture and some to and froing with DSL connections have taken up most of my available time.
Returning to the clean install of 10.04.2 that I should be up to, one small ? question ?. When I have got to the sizing of partitions and have got the right sizes how do I ensure that when / fills up with the biggest part of the OS, the /home does go to the empty sda3? I seem to remember reading that there would be some hoops to jump through to get the mount point in the right place to stop / putting its own /home in /? Does labelling sda3 as /home do it all for me? You will remember (with shudders) that this was a basic problem in the first place many posts ago.
29-05-2011 12:43 PM
Follow the part with the heading "Here's how you do a manual partitioning with /home:"
with these screenshots
29-05-2011 6:13 PM
So if you want to you can have
sda1 as /home
sda2 as /
sda3 as swap
or more usually
sda1 / (10+ Gb)
sda2 /swap (whatever)
sda3 /home (rest of disk)
So you don't end up with the situation of 2 (or more) partitions/folders called home.
30-05-2011 11:24 AM
I thought that it would be automatic using the labelling of the partitions, it was a possible pothole remembering my original problem and did not want to fall into it again!
Download speeds of around half my upload speeds are my main consideration rioght now!!
31-05-2011 7:33 PM
03-06-2011 2:45 PM
Sorry! Too busy to find enough time to concentrate on this right now. All the valuable advice safely stored. Hope to have more on the subject before long. Man organised by PN coming on Monday pm to look at my set-up, if he is successful, may do a bit more partition-bashing then.
Thanks to all.
C.
- « Previous
- Next »
