Firefox 3.5
Firefox 3.5
Just going back to the Firefox update (from previous thread). Now it has been downloaded as an update (last night). However, on Help it says I am still on 3.0.11 so please can someone tell me if I need to do anything to complete the update? Tried the terminal command but couldn't get it to work - wouldn't take password.
This installation is the Ubuntu one.
Re: Firefox 3.5
I found the auto update would not upgrade to 3.5, I had to go to the Mozilla site and download 3.5. - on Windoze XP & Vista
Fixes: 10
Re: Firefox 3.5
Update worked for me on XP (two PCs)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 185
Re: Firefox 3.5
worked on my win and mac PCs OK
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Waldo
Re: Firefox 3.5
Presumably you have two versions of Firefox installed. What is the output from                                            [1]
$ ls -l /usr/bin | grep firefox
Something else worth trying (I'm not sure if Ubuntu uses it or if it's Debian specific)
 $ sudo update-alternatives --config x-www-browser
This should give you a rudimentary menu allowing you to set the preference for your browser of choice.
From the information so far it sounds as though the Ubuntu developers have added FF 3.5 to the Ubuntu repos but not yet amended all the dependencies which would allow the previous release to be removed without taking other parts of the system with it (you have tried to install the earlier release?)
If you just want to take FF 3.5 for a spin you can launch it from the command line, add it to the GNOME menu or add a launcher to the GNOME panel (based on the output from [1] above.
Re: Firefox 3.5
Waldo - thank you for your help. Here is the output from the first command:
lrwxrwxrwx  1 root   root         11 2009-06-20 18:35 abrowser -> firefox-3.0
lrwxrwxrwx  1 root   root         11 2009-06-20 18:35 abrowser-3.0 -> firefox-3.0
lrwxrwxrwx  1 root   root         11 2009-07-08 21:21 abrowser-3.5 -> firefox-3.5
lrwxrwxrwx  1 root   root         11 2009-06-20 18:35 firefox -> firefox-3.0
lrwxrwxrwx  1 root   root         32 2009-06-20 18:35 firefox-3.0 -> ../lib/firefox-3.0.11/firefox.sh
lrwxrwxrwx  1 root   root         29 2009-07-08 21:21 firefox-3.5 -> ../lib/firefox-3.5/firefox.sh
and here is the one for the second command:
[sudo] password for xxx:
There are 2 alternatives which provide `x-www-browser'.
  Selection    Alternative
*+        1    /usr/bin/firefox-3.0
          2    /usr/bin/firefox-3.5
Press enter to keep the default
  • , or type selection number: 2
    Using '/usr/bin/firefox-3.5' to provide 'x-www-browser'.
    So what you have said is correct. I selected '2' and pressed enter but it hasn't changed the browser version, even after reboot. Am I doing something wrong?
    BTW can you just remind me how to get the vertical line (i.e. which key combinations)? I have had it before but can't recall what I did.
  • Community Veteran
    Re: Firefox 3.5
    Upgrade worked fine for me after I restarted the browser.  Can't say I can see much difference with the earlier version.
    Re: Firefox 3.5
    Have done something else and now managed to get Shiretoko which is Firefox 3.5 (beta version?). Glad yours updated OK artmo - makes me wonder what I did wrong.
    Re: Firefox 3.5
    Looked things up and it appears that what I have is what you get! Shiretoko (or Browse the Bleeding Edge) is Firefox 3.5 unbranded. It would seem that 3.0 stays in the repository and that 3.5 does not replace it.
    According to what I've read it will be branded in the next version of Ubuntu.
    pierre_pierre
    Re: Firefox 3.5
    | on mine its shift Fn Z
    Re: Firefox 3.5
    Thanks for that Pierre - just come out from the recesses of my addled brain and found it. On mine it's Alt~Gr and |.
    Shall have to write it down somewhere but I should probably forget where I have put the bit of paper!
    Waldo
    Re: Firefox 3.5
    Quote from: poppy
    [me=Waldo]makes mental note to engage brain before keyboard[/me]
    Yes, you're assuming I know what I'm talking about  Embarrassed
    I was barking up the wrong tree with that one (or just plain barking...)
    What you really want is to change the firefox -> firefox 3.0 symlink to a firefox -> firefox-3.5 symlink.
    Bearing in mind the above are in /usr/bin:
    $ sudo ln -sf /usr/bin/firefox-3.5 /usr/bin/firefox
    where ln -s creates the soft (symbolic) link and -f forcibly removes the existing link (and, yes, it does look a bit back-to-front).
    I use AltGr & \ (backslash); for a permanent reminder:
    $ echo "AltGr & \ = |" > useful_keystrokes.txt
    pierre_pierre
    Re: Firefox 3.5
    OK then can you bark a bit louder, this machine is an Eeepc 701 4G on linux, it comes pre installed with FF 2.0,  I have auto upgraded several program on it, but so far no offer from them on FF.
    Recently on normal shut down FF is reporting abnormal shut down and asking me to send in a report, I am starting to get annoyed.
    Bearing in mind the severe lack of space, how or can I put on FF3.5
    Fixes: 185
    Re: Firefox 3.5
    Here is a starting point http://forum.eeeuser.com/viewtopic.php?id=67903...
    pierre_pierre
    Re: Firefox 3.5
    ta reading it looks OK will give it a try when back home from baby sitting 93 year old mum
