Firefox 10.0.1
Fixes: 238
Firefox 10.0.1
Maybe I just never noticed it before or has FF changed what happens when click on the arrows eiether end of the Tabs bar.
It seems now if you double-click on the arrow it rapidly moves to the next  of unseen set Tabs. Did it used to happen this way or is this new - I just can't remember?
Ooops, this should have been posted Windows Software. Could a mod move it, please Embarrassed
Forum Moderator and Customer
pierre_pierre
Re: Firefox 10.0.1
dont know how many tabs you have, mine just get smaller, only one arrow, a down one that brings up a list  FF 10.01
Fixes: 238
Re: Firefox 10.0.1
Currently 31 tabs in one window.
pierre_pierre
Re: Firefox 10.0.1
didnt like 45, but what you said works
Fixes: 5
Re: Firefox 10.0.1
As this thread is about Firefox, I have last night uninstalled it, as it had started to use the hard drive excessively.  Every time I started it up, the hard drive on the laptop came on and refused to go off, and the internet was sluggish, for at least 10-15mins.  This didnt happen in IE9 or Chrome.
I was on the latest version of it, but when I uninstalled I appeared to have 2 versions, not sure why.....
If anyone can help, I would appreciate it, as I ran out of ideas... Cleared the cache, ran CC Cleaner, disabled add-ons, ran in safe mode, all to no avail.  I like firefox, but not if it does this.....
Steve
Seasoned Pro
Re: Firefox 10.0.1
FF 10.0.2 Is out now, Can you keep up? I certainly cant.
If life gives you lemons, make lemonade.
Fixes: 178
Re: Firefox 10.0.1
I've noticed Steve, I'm on V11.0 Smiley
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
pierre_pierre
Re: Firefox 10.0.1
I have had a job  stopping it,  dont really know what the problem is, but SWMBO XP netbook doesnt like 10.0.2,   it wont connect to the internet, I have to keep reloading the only old copy I have 8.0
Think I have stopped it now
Steve
Seasoned Pro
Re: Firefox 10.0.1
@Strat, Some interesting features coming then In March. Smiley
VileReynard
All Star
Fixes: 11
Re: Firefox 10.0.1
I have 1 tab in each window; that way I don't waste space on a tab bar.  Cheesy
