FireFox Tabs
Fixes: 192
FireFox Tabs
I used to like how a new tab would open just to the right of the current tab in IE 7 (6 as well, I think). This seems to have changed in IE8.
Not that bothered as I now use FF but I find that all new tabs appear at the far right and not next to the current one.  Have search all the options and cannot see a way of changing this. Is there?
Cheers.
Forum Moderator and Customer
Fixes: 10
Re: FireFox Tabs
Do you use the Tab Mix Plus add-on in Firefox? (that has an option Open new tabs next to current one)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 192
Re: FireFox Tabs
Thanks Jelv
Just the ticket Smiley
