Filtered faceplate over basic microfilter.
- Re: Filtered faceplate over basic microfilter.
21-02-2009 4:13 PM
Possible improvement in the sync rate/attentuation?
21-02-2009 4:40 PM
But it looks much neater.
If you also get a filtered bell wire (and have extension phones), then you can get dramatic improvements,
Your required noise margin for stability can be greatly reduced, allowed an increased sync speed.
[An i-plate will do this for about £10 - but you still need those trailing filters.]
The first step is to measure your noise margin - if it's about 6 - 9dB then it's probably not worth doing anything.
If it's bigger than that - try getting PN to reduce it and if this fails, start thing about various faceplates / i-plates.
21-02-2009 5:29 PM
Quote from: Axis The first step is to measure your noise margin - if it's about 6 - 9dB then it's probably not worth doing anything.
I've always had a noise margin of 6dB, but by fitting a filtered faceplate and thus sorting my internal wiring my speeds more than doubled.
21-02-2009 5:41 PM
21-02-2009 6:15 PM
Like one from maplins over adsl nation?
21-02-2009 6:27 PM
21-02-2009 10:45 PM
Here were my stats
27/07/08 5280 ds 9
28/07/08 5376 ds 9
29/07/08 5408 ds 2
30/07/08 5248 ds 3
31/07/08 5344 ds 7
01/08/08 5248 ds 6
02/08/08 5504 ds 7
03/08/08 5280 ds 6
04/08/08 5312 ds 7
They were with the bell wire removed
30/01/09 6240 ds 2
31/01/09 6144 ds 2
01/02/09 6208 ds 3
02/02/09 6016 ds 6
03/02/09 6208 ds 6
04/02/09 6272 ds 4
05/02/09 6208 ds 6
06/02/09 6240 ds 4
07/02/09 6144 ds 6
08/02/09 6336 ds 4
These are the stats since having the facplate and high speed modem cable to me its evidence that the cable/plate works my sync speed used to be 3500 now its 5000. The cable is a lot better than an extension if its for BB
If your speed is above 7000 then any increase would be very small
21-02-2009 10:55 PM
but if you use a length Cat5 or high speed cable between your router and telephone sockets - how does that help if you then have a kilometer or so of CW1308 twisted pair / unscreened cable or equivalent with thicker outer covering to the exchange, via one or two distribution boxes with wires exposed ?.
Just a bit puzzled ?
21-02-2009 11:02 PM
Then your speed will not change!
(Things should be different on ADSL2+ though).
Generally, you will get a better improvement if you are cluttered up with telephone extensions (especially unused ones).
I assume that your router is plugged directly into the BT master socket?
I think samuria is reffering to the wire from BT socket to router and the need for it to make good physical connections.
21-02-2009 11:02 PM
I used to do a lot of network problems in the ICI factory and the noise cables pick up is surprising moving a cat 3 cable 2 feet meant the difference between a printer working or not
21-02-2009 11:16 PM
But of course you are right - if it works it works -
But just a tale - when I first brought this laptop home and wanted to connect to the router in the office with the desktop and work in the lounge ( no wireless ) al I had was one of those horrible cheap extension leads with 15 meters of flat cable. I thought - this will never work - but it did and I got a sync of about 5M !!. I was amazed.
I still don't use Cat5 - just a reasonable twisted pair - and I get 7M. But I do live in the country, and it's very quiet electrically here.
[edit - not like an industrial site - ]
This ADSL is a funny unpredicable beast at times.
21-02-2009 11:43 PM
There are advantages to being out in the sticks - no RFI.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
22-02-2009 9:45 AM
Quote from: Samuria I saw a difference the second I plugged it in.
Ditto.
Replaced my ISP-supplied router cable with an ADSLnation (0.5m) one and went up 500k or so.
22-02-2009 10:08 AM
22-02-2009 1:39 PM
