File sharing from XP to Win 7; is my Technicolor TG582n blocking ports?
- File sharing from XP to Win 7; is my Technicolor T...
27-10-2013 10:28 PM
Hi all, having an unreasonable amount of difficulty getting my Windows 7 machine to see a shared folder on the XP one.
I've tried quite a lot of self-help guides but with no luck. I'm starting to wonder if the router is blocking the connection for some reason but don't know how to test that - any ideas?
I can see the XP in the Win 7's Networking view but when I click through I get a long pause and an error. Windows suggests I make sure it accepts incoming connections for file and printer sharing. All firewalls turned off. I can't ping it (but the name does resolve).
I've been through all the menus and settings to enable sharing on the XP machine - workgroup is set correctly and matching, file and printer sharing enabled, the service is running, I have some folders shared with no security on them. XP is wired with the supplied cable, Win 7 is via wireless.
Any help much appreciated!
3 REPLIES 3
Re: File sharing from XP to Win 7; is my Technicolor TG582n blocking ports?
28-10-2013 7:00 AM
Sharing can be difficult if there is no Windows login password set. If so, just go to Control Panel, User Accounts and set a password.
28-10-2013 7:24 AM
Hi there, I had a similar problem but managed to get it working following the instructions on this site:- http://www.howtogeek.com/howto/windows-7/share-files-and-printers-between-windows-7-and-xp/
Good luck, robski1
Good luck, robski1
29-10-2013 11:26 PM
Hi both, thanks for the replies. Actually, the link is for sharing the other way, but they do have instructions for what I wanted on the site as well.
I'm sorry to report that today it's working. I swear I've changed nothing - perhaps everything just needed some time (or *yet another* reboot) to settle down?!?! I didn't need any passwords either (by the looks of things I would need a password to export a share from 7 to XP though).
Thanks again
Thanks again
