File path
tonka
File path
Hi i have a problem with my file path with pictures,when i click on pictures in start menu on windows xp it is taking me to my documents instead of my picture's,how do you change the file path to display my pictures? many thanks.
kmilburn
Re: File path
You'll need to modify the appropriate "User Shell Folders" key in the Registry.
This provides some handy instructions http://windowsxp.mvps.org/usershellfolders.htm
Fixes: 19
Re: File path
Alternatively.... put a short-cut icon on the desktop....  Wink  goes straight to your pic folder...
