File Delete/Paste W10
Mav
Fixes: 454
Since the demise of my trusty PC (self-build in 2012) where the power supply seemingly took out the motherboard, a couple of HDDs amongst other things I have had to start again with a new self-build but with W10 Pro. Yeah, I know I said I would never use it but with W7 support being discontinued early next year it left me with no choice. In fact, using the latest version (1903) I have things looking more like W7 with the benefits offered by W10 plus the great thing was I could use my W7 Pro licence to activate W10 Pro saving up to £200!
Anyway, under  W7 Pro I could use Alt+E then Alt+V to move a file/folder with ease. This brought up a dialogue box in which I could choose where to move the file to including creating a new folder(s). This was very quick and convenient but seems absent in W10 Pro. All my searching has not found a solution - is there something similar?
New build specs (if anyone's interested):
Cooler Master 625S Case
ASUS X470 Prime Pro MB
AMD Ryzen 7 1700 8-Core CPU
ASUS NVIDIA GeForce GTX 1080Ti 4GB DDR5 GPU
120GB Crucial BX500 SSD for temp files, etc.
32GB (2x16GB) Ballistix Sport DDR4 3000MT/s RAM
Samsung 970 EVO Plus 250GB SSD for System files, etc.
Corsair 750W 80 Plus Gold fully modular PSU
Syba PCIe 4 Port SATA III Controller Card
2 x 2TB 7200 HDDs
plus from old PC
3  x SSD (240,100, 60GB)
2 x HDDs (2TB and 500GB)
Forum Moderator and Customer
7 REPLIES 7
Fixes: 1,317
Re: File Delete/Paste W10
I can tell you how to do it on macOS Tongue
Mav
Fixes: 454
Now where's that 'Ignore' button Funny
VileReynard
Fixes: 20
Surely CTRL+X, CTRL+V (cut & paste from source to destination) works?
Does for me on all Linux file managers that I've tried, anyway.
Mav
Fixes: 454
Yes, that works but if you want to create a new folder at the destination then that has to be done first.
Browni
Aspiring Hero
Fixes: 52
Those short cut keys are not part of a standard Windows install, it must have been an add-on of some sort, Power Toys possibly?
Ex-Plusnetter now living life in the G,fast lane!
Mav
Fixes: 454
I don't remember having an add-on but it's not impossible. Haven't heard of Power Toys.
idonno
Champion
Fixes: 6
Have a read windows keys
Power toys, yep, the good old days. Same with God mode!
Edit to correct bad link Smiley
Ever helpful. Grin Sure, I’d love to help you out. Now which way did you come in?
