File Conversion.
- File Conversion.
File Conversion.
24-07-2012 5:21 PM
I Could either use Libreoffice or Word 2007, does it make any difference which I use ?
Is there any free software (other than Calibre) that is better for converting PDF to MOBI.
Any comments on this topic would be appreciated.
Re: File Conversion.
24-07-2012 8:03 PM
The best you can do is to use OCR software to get text.
24-07-2012 8:20 PM
24-07-2012 8:34 PM
As you've found, document (format) conversion can be a very hit-and-miss affair however trying a variety of methods will give you a good idea as to the art of the possible which may or may not be good enough.
You say you are happy to convert via 'TXT files' - this suggests you are content for all formatting to be removed (given that such files only support human-readable ASCII). If this is the case you could just copy-and-paste all the text from the PDF into a TXT file, remove any extraneous whitespace, and then convert to MOBI using Calibre.
It's a shame that the Kindle has such poor support for native PDF documents given that in many respects they are quite a convenient format choice.
Mathew
24-07-2012 8:36 PM
24-07-2012 8:58 PM
Since you have already bought the book once, why not get a second version for free from the Pirate Bay?
24-07-2012 10:28 PM
The document may only be available in PDF i.e. not a book (it is a relatively rare format for paid books).
Mathew
24-07-2012 10:43 PM
The format has remained essentially constant for hundreds of years.
25-07-2012 8:49 AM
As others have said if the PDF is an output from a scan then nothing will work (as the PDF is simply a wrapper around a graphic) and no ereader will make a very good job of rendering it.
25-07-2012 11:20 AM
