Fibre to the Remote Node (FTTRN)
dws1900
Hi
Is anybody on one of these?
Is it pole or in the below ground connection box?
Any issues?
What is FTTRN?
A VDSL (FTTC) based service using a small footprint DSLAM and copper rearrangement to deliver fibre
broadband
For smaller communities
What are the key differences to FTTC?
Smaller capacity, lower cost per node
Multiple Deployment Options – Green Cabinet, Pole Mount,
Footway Box, MDU
Remotely Powered option – Power multiple FTTRN from single location up to 1.5km away
1 REPLY 1
Fixes: 1,473
Re: Fibre to the Remote Node (FTTRN)
Moderators Note
This topic has been moved from Fibre to Tech Help
