Fibre to the Home/Cabinet on it's way?
- Re: BT and fibre optics
15-07-2008 11:12 AM
BT may be sticking their hand in their pocket to roll out FTTH/FTTC?
Whatever next!
B.
Re: Fibre to the Home/Cabinet on it's way?
15-07-2008 11:27 AM
As BT want a "return on their investment", I assume that they're not wanting to open it up to other providers and you'll need to go to BT to get the faster speeds. From the BBC article:
Quote However, the communications group has made clear it will only make the move if regulator Ofcom allows it to get a decent return on that investment.
15-07-2008 11:59 AM
Quote A key point made by BT is that these fibre based products will be available at a wholesale level, which will increase the pressure on Virgin Media to provide a similar service.
So it looks as though it'll be open to all providers!
15-07-2008 12:20 PM
15-07-2008 12:28 PM
So.. how long until the heavy users start suffering connection problems?
Answers and bets on a postacard..
15-07-2008 5:46 PM
16-07-2008 8:12 AM
Any network is only as good as its weakest link - BTs weak link is the copper from the exchange to our homes via the 'green boxes'. If they can remove a large part of that weakness and leave folks with lines only a few hundred metres long, the result will have to be good.
Capacity will still be a potential problem, but even if we assumed we'd all get the same speed we do now, latency would still be reduced giving a superior service. Increasing speed and decreasing latency would be a a real boon.
One aspect not mentioned yet though is the LLU aspect; if BT were to start putting their equipment into the cabinets to enable the use of fibre, would they have to allow other operators to do likewise?
18-07-2008 12:07 PM
Quote from: James_H One aspect not mentioned yet though is the LLU aspect; if BT were to start putting their equipment into the cabinets to enable the use of fibre, would they have to allow other operators to do likewise?
This is already happening apparently
http://www.samknows.com/broadband/news/sky-begin-fttc-trial-397.html
BT and fibre optics
18-07-2008 2:54 PM
http://news.bbc.co.uk/1/hi/business/7506742.stm
Cheers
Rob
18-07-2008 3:02 PM
/fcel spits out half eaten dictionary
18-07-2008 3:32 PM
18-07-2008 3:44 PM
I've Merged 2 topics on BT's FTTC plans into one...
Daniel
18-07-2008 4:03 PM
Found it by backtracking from the poster's posts
26-07-2008 3:59 PM
