Fibre not working on some devices
- Re: Fibre not working on some devices
27-07-2019 12:28 PM
27-07-2019 2:50 PM - edited 27-07-2019 2:55 PM
@Susanowlwilson Welcome to the forum.
I assume that if you are using wireless that you have gone into your available wireless settings and selected your router WiFi?
Alternatively if it's a Windows laptop try the following:
1. Type cmd into the search box on the bottom left of your desktop.
2.This should come up with a link to the Command prompt. Right click this and select 'Run as Administrator'. You may need to enter an administrator password unless you are already logged in to Windows as an administrator.. A new pop up box should appear.
3. Type 'ipconfig /release' (without the inverted commas).
4. After you get a response type 'ipconfig /renew' (without the inverted commas).
See if that fixes it.
27-07-2019 4:54 PM
Moderator's Note(s)
Thread moved from Fibre Broadband to Tech Help.
Forum Moderator and Customer
28-07-2019 1:41 PM
Hi @Susanowlwilson,
I'm sorry to hear that you're unable to get online on your laptop after tethering it to your phone whilst you were away. It sounds like the issue lies with the wireless settings on the laptop. Please can you run through the steps that @Baldrick1 has suggested and let us know if this doesn't resolve the problem.
01-08-2019 9:41 AM
