Fedora 10
- Fedora 10
Fedora 10
15-11-2008 10:44 AM
Fedora 10 is scheduled for release on the 25 of November.
http://fedoraproject.org/
After my sabbatical with Ubuntu, if feel that it is time to head back to RedHat.
And as I am no longer using my Linux machine to run servers on vwmare, I can risk stability and go cutting edge!!
Chilly Distribution history;
Of course not forgetting Xandros on my eeePC and the various `Live linux's`.
- Mandrake
- RedHat
- Solaris
- SMEServer
- CentOS (With SMEServer in VM)
- Ubuntu
- Fedora?
6 REPLIES 6
Re: Fedora 10
15-11-2008 2:10 PM
just thinking Chilly still not plucked up courage to hack my EeePC
looking at your sig Who watches the watchmen (Quis custodiet ipsos custodes) perhaps its me and my Avatar
Re: Fedora 10
15-11-2008 8:31 PM
Vir sapit qui pauca loquitur
Literally "The man is wise who talks little".
Colloquially "Know when to hold your tongue"!
Re: Fedora 10
28-11-2008 8:01 PM
Well that did not last long!!!
I have always found Fedora a bit `work in progress`. I am now back on CentOS but with rpmforge repo enabled.
Re: Fedora 10
29-11-2008 5:40 PM
Quote from: chillypenguin Well that did not last long!!!
What specifically didn't you like about it? I've just reformatted my PC and was considering putting Fedora 10 on the non-Windows partition instead of Ubuntu. I got wind though that it wouldn't get on with my Nvidia GFX drivers.
Re: Fedora 10
30-11-2008 9:19 PM
To be honest the few days that I was running it, I did not really give it a chance.
I ended up in dependency hell trying to install the drivers for my printer (Serves me right for buying a Canon, and expecting it to run on Linux!!!).
But then CentOS has the same issue with the Canon driver (cured with TurboPrint).
The visual effects were a great gimmick at first, such as the cube workspace switcher, but soon become annoying. And the places for every thing in the menus had been moved around, causing a hunt for everything.
I am very much a Luddite, in that I prefer old stable and working, so I returned to my old and trusted CentOS (RedHat Enterprise Linux).
Why not give CentOS (5.2) a try, its basically RedHet EL without the price tag, so you get an enterprise and very well respected distribution. One snag it does have is that the standard repository's only contain a small selection of software. But you can always enable the rpmforge repo.
Re: Fedora 10
04-12-2008 12:33 AM
Quote from: Bob
I have to agree that Fedora is not the most complete product out thare after install on a system that has an Nvidia card, this is mainly to do with its 'noble' intention og being a truly 'free' distro and any propriety drivers would taint that.
So you have to add specific 'non-free' repositories to the package manager (I also do not presently like packagekit - it seems cumbersome), one the non free repos are added you can then install the appropriate graphical server and reboot to activate.
It would take quite some work for me to get a fedora install to look/feel right for me.
Should you need the non free repo, have a search ogn the fedora forum for a thread called somthing like 'nvidia F10 guide' or similar
Jase
