Faster way to convert to Mp4?
- Faster way to convert to Mp4?
- « Previous
- 1
- 2
- Next »
Re: Faster way to convert to Mp4?
23-09-2012 7:54 PM
Quote from: LukeAger Currently using handbrake to convert any movies i have from avi to mp4 (simply so that i can add the movie to my itunes and then to ipad.)
Handbrake seems to take a massive amount of time to convert these. About 45-50 mins to convert a 2 hours film.
Does anyone know of a program which may speed up this process?
Using 2006 Imac
Processor 2.16 GHz Intel Core 2 Duo
Graphics ATI Radeon X1600 256 MB
Memory 3 GB 667 MHz DDR2 SDRAM
The OP is talking about iMac software so probably OSX, not Linux .... ie Handbrake.
See post #5...
I know it's available on various platforms
http://handbrake.fr/
Message 16 of 20
(252 Views)
23-09-2012 7:59 PM
Possibly... I assumed that it was LINUX. being in this forum section... and as you say.. not mentioned which OS he is using...
Message 17 of 20
(252 Views)
23-09-2012 8:15 PM
Of course, all of this may be irrelevant, my older 2007 iMac G5 White 17" Superdrive won't even run 10.7, let alone 10.8, so QT10 may be out of the question !!
It's supposed to work with 10.6.8 though
[color=red]What is QuickTime X?
QuickTime X is the next-generation media technology that powers the audio and video experience in Mac OS X v10.6 and later.
Having re-read post #5 with OP's iMac spec.[/color]
In which case, perhaps Quicktime Pro £20, is an option
http://store.apple.com/uk/product/D3380Z/A/quicktime-7-pro-for-mac-os-x
Message 18 of 20
(252 Views)
24-09-2012 8:50 AM
Thanks guys. I am using iMac OSX. I have changed the output file to a lesser quality which had reduced the conversion time. Iv also found the iMac is overheating when the CPU is struggling. I have tweaked a few things in the fan control to improve cooling although having now read PlusComUK's latest post I may try using the Quicktime process. Thanks all for your suggestions.
Message 19 of 20
(252 Views)
24-09-2012 1:53 PM
I bet you find that you will exchange conversion speed for file size and/or for quality degradation.
Message 20 of 20
(252 Views)
- « Previous
- 1
- 2
- Next »
