Fanvil GA10 UK Ring Type syntax
Batfrog
Does anyone have the correct syntax for UK ring type in an Fanvil GA10 / 11. Mine is set to the default which seems to be the North American one. Ringing out is the UK type.
Not a functional problem just b annoying !
5 REPLIES 5
corringham
Seasoned Champion
Fixes: 23
Re: Fanvil GA10 UK Ring Type syntax
Doesn't it default to the UK tone settings if you select the UK in the Country config in the tone settings?
I don't know  - just had a quick look at the manual online.
Batfrog
@corringham: Doesn't it default to the UK tone settings if you select the UK in the Country config in the tone settings?
Sadly not ! The UK tone setting you refer to is for the ringing out tone. The incoming ringing tone seems to be set in the ‘Phone settings’ Media tab under ‘Ring type settings >>’
Changes to this (these) setting changes the incoming ring pattern but I can’t seem to get it to ring as you would expect a normal UK phone.
Thanks anyway
Fixes: 1,495
Moderators Note
This topic has been moved from Everything Else to Tech Help
RichardB
Seasoned Champion
Fixes: 39
Batfrog
Hi@RichardB  Thanks for that I'll investigate.
regards
