Fair use policy
colaker
Fair use policy
Although I'm now on unlimited broadband, though am usually well under 20gb /month. However my daughter and family are between houses and staying with us temporarily. The broadband traffic is way above 20 - will there be any repurcussions ? I don't mind if it's throttled but don't want to find it's suddenly cut off before the end of the month.
1 REPLY 1
Chris
Legend
Fixes: 169
Re: Fair use policy
No fair usage policy, so don't worry about it. It's unlimited so you can use as much as you want.
