Failed Update
- Failed Update
- « Previous
- 1
- 2
- Next »
Re: Failed Update
08-11-2010 6:48 PM
I have attached a snip of the failures.
I have looked at the link and am terrified of using the clean up tool in case it goes badly and messes my machine up.
The blog does contain a caveat.
I would rather repair it if possible but any other ideas most welcome.
I have run Kaspersky vulnerability scan and it is not showing up so I am wondering just how important this really is.
If I can do without .NET I will just leave and forget about it.
Re: Failed Update
08-11-2010 6:55 PM
Re: Failed Update
08-11-2010 7:04 PM
Re: Failed Update
08-11-2010 7:15 PM
Edit, At the end of the day don't lose any sleep over It, Windows 7 Service pack 1 will be with us soon, You will get them all with that.
Re: Failed Update
08-11-2010 7:36 PM
on my pc
if you delete net framework , when you reboot
your pc is likely to be missing files and the pc will shut down
ad infinitude
my pc works with out the update
however this update is over a security issue in the previous version of net framework
only problem is the update wont install over the last update
it has to be removed to install this latest update
dont remove it , and install the update until more is known
perhaps microsoft will update the update as it fails to install
Re: Failed Update
08-11-2010 7:43 PM
Quote Edit, At the end of the day don't lose any sleep over It, Windows 7 Service pack 1 will be with us soon, You will get them all with that.
Thank you Steve - that is just what I wanted to hear. Going to leave it for now.
Re: Failed Update
08-11-2010 7:45 PM
and it boots into your desktop
and all your programs work ok
then just download the single 'exe file '
to then re install its upgrade
but back up your entire drive before using the clean tool from ms
i'm trying to install the same update as poppy
but cant
Re: Failed Update
09-11-2010 4:08 PM
Re: Failed Update
12-11-2010 10:45 AM
Re: Failed Update
12-11-2010 2:37 PM
- « Previous
- 1
- 2
- Next »
