FRITZ!Box 7530 as DECT base
jric
Does anybody please have experience to help me sort out my VOIP set up??
I have a Yealink SIP-T31P phone plugged into the Plusnet Hub Two router which works fine.
I have a FRITZ!Box 7530 set up as an IP client acting as a wi-fi extender+switch in another part of the house which also works fine (via powerline).
My problem is trying to connect a DECT handset to the FRITZ!Box (FB) as a DECT base station. I have registered the handset to the FB and it pairs with it OK. But it won't ring or dial out (engaged signal).
The FB overview page shows "Telephony: one phone number active, none registered". The System Event Log shows registration failed "Reason for error: DNS error".
I have tried every possible solution from the FB Knowledge Base and internet searches, messing with port forwarding, fixed IP addresses and lots of router settings without having a clue what any of them mean and without success – the number of computations of combinations I could change would probably be on a par with winning the Lottery! I have no idea where the blockage is and am not at all network savvy.
Is the answer much simpler? Would it help to register the Yealink with the FRITZ!Box perhaps? Do I need to register the handset as an extra device with the VOIP provider? I don't want another extension though, nor to mess up the existing set up – I just want both phones to ring at the same time and to be able to dial out or answer on either.
16 REPLIES 16
Fixes: 585
Re: FRITZ!Box 7530 as DECT base
@jric
How is the 7530 configured and connected ? I suspect as a wireless AP (DHCP disabled) and connected via a LAN port ?
Most routers with built-in VOIP facilities will assume that the voip connection is made via the WAN. In your case there is no WAN and so it can't connect
Fixes: 118
@jric
Can't really help but have you tried unplugging the Yealink device and then trying the FritzBox?
Fixes: 585
@jric further to my earlier reply, it seems the 7530 MAY be able to operate its voip client when in IP Client mode.
Use the option 3 here https://fritz.com/en-pl/apps/knowledge-base/fritz-box-7530-ax/177_Conducting-calls-with-the-FRITZ-Bo... to 'setup automatic port forwarding' which should keep the NAT session in your main router open and thus avoid the need for any port forwarding on that router
I still dont like the 'Reason for error: DNS error' , that implies the 7530 cant resolve the url for the voip server.
PhilipHeyes
Seasoned Champion
Fixes: 27
We have 3x SIP / VoIP accounts, here are a few items to consider :-
Both the Yealink SIP-T31P and the FRITZ!Box 7530 will be configured with your SIP / VoIP a/c,
they both have to register.
To use two VoIP devices, make sure there is not a clash of inbound ports,
i.e. the two VoIP devices need to use different inbound ports.
This reads like FRITZ!Box 7530is being used as a Wireless Access point, so DHCP & Firewalls & NAT should be disabled.
Double NAT needs to be avoided at all costs with VoIP, it is a primary cause of one way voice issues.
The primary Hub / Router will be offering the DHCP service and giving out an IP that has a valid DNS.
jric
MisterW: Overview shows 'Internet connected via WAN', and 'LAN connected LAN 1'... Telephony DECT Monitor even has a pretty little picture of the handset!
Fixes: 585
In that case as @PhilipHeyes says you need to make sure both sip devices are using different ports. Disable any port forwarding on the main router, disable stun on the Yealink if its enabled. Set both vothe dealing and 7530 to use 'nat keep alive. For tteb7530 option r in my earlier post.
That way the NAT translation in the main router will ensure that different public ports are used
PhilipHeyes
Seasoned Champion
Fixes: 27
That DNS error that was mentioned catches my attention. What is that about ?
We keep STUN Enabled on all of our VoIP phones & I use the SIP / VoIP providers STUN server.
I agree Router Port forwarding is to be avoided this is the route folks follow when they are totally lost
and have failed to configure the VoIP devices correctly or failed to allocate different inbound ports to each,
or have 2 routers involved and the devices on the 2nd router do not work.
Batfrog
@jric
Have you registered your VOIP account in the Fritzbox telephony section ?
Telephony /Phone Numbers/ New Phone Number.
You don’t mention it in your OP.
jric
Thanks to everyone for answers. Sorry, I'm not ignoring posts, just quite a few suggestions to ponder now, some of them contradictory, so will need to try them out in practice when time allows.
Nobody is saying here at least that this isn't possible, but I have since been in touch with VOIP provider who says I need to make each phone into a separate extension, which I don't want to do (as apart from costing more I'm thinking perhaps that if this is a registration issue it might not work anyway).
Yes @Batfrog, all entered in Fritzbox, but perhaps incorrectly in some way, which would also lead to DNS error message?
I think that what I want to do is called SIP forking – but provider, Fritzbox and my own ignorance are combining to thwart what seemed a simple idea. I will experiment in the next few days and report back with any solution – or more questions!
Fixes: 585
@jric
Who is the voip provider ?
Some (most?) providers allow multiple registrations against the same account.  I know that Sipgate, A & A & Localphone do.
PhilipHeyes
Seasoned Champion
Fixes: 27
Contradictory advice .... not quite, more there are options.
The question of use of a STUN server is simple, we each follow our SIP/VoIP providers installation guide to the letter.
The DNS issue needs to be solved immediately.
Why does the Fritz box not have a working DNS  ?
Is that because the Fritz box  is still configured as a ROUTER for an ADSL or FTTC connection that no longer exists ?
jric
Thanks to all who tried to sort me out. Apologies for response delay – we had a near lightning miss and the Plusnet router in question was fried, AND the computer connected to it! But thankfully not the SIP phone. I have spent a lot of time with Openreach, Apple repair, etc (but computer was terminal), and I have had enough of IT matters to last me a while!
VOIP provider tells me I can't do what I need without new DECT device being registered as another extension. Would that account for the DNS error message i.e. it's their server rejecting? But I would then presumably also need to pay extra to put 2 phones into a call group, not sure. But I am going to give it a rest for now and re-think the system.
Will re-post if I come back to it and get sorted.
jric
Here is an update – after buying a very expensive new computer, Plusnet providing a new router, and three different visits from Openreach (fourth pending)!)
Well, I finally got both phones configured on the Fritzbox to register and at last the little green dot appeared on 'Telephony: one phone number active'. To be honest I don't even know what I did to make it work, as I had tried so many different settings! But it CAN be done Smiley
But there was no port forwarding involved (yet) and nothing to do with changing network settings.
So, I can now pick up either phone and dial out OK. Incoming calls also work fine, including excellent voicemail on Yealink and by email. EXCEPT it is a case of either/or in that only one of the phones will ring and the other stays dead (dialling tone). This seems quite random as to which one takes the call.
I have tried directly connecting the Yealink to the FritzBox but that makes no difference.
I know I'm displaying my ignorance but I can't see a reason why the two phones can't be made to ring at the same time. Even if there is a rule at the VOIP service end set that only one phone per extension can be active, surely it is the FritzBox itself that is registering and so once the incoming call has got into that router, it should at least be possible to set things up to decide on which phone is actually going to ring even if they don't ring together?
Fixes: 585
It depends on the voip provider. Some allow multiple registrations on the same account, in which case usually all phones will ring and the first to be picked up will accept the call.
From what you said earlier in the thread, your provider doesnt allow that and you have to have separate 'extensions'.
What happens to an incoming call depends entirely on how the voip service routes the call to the extensions.
Who is your voip supplier ?
