FREE windows Filemanger
- Re: FREE windows Filemanger
31-12-2008 11:14 PM
Just came across this beauty and as always thought I would share it. I use Powerdesk but this free one matches it and its free and you can just copy it to a USB stick and take it with you and it will work. It gives you a lot of extras that you dont get with windows file manager
Main features in FreeCommander:
* Dual-panel technology - horizontal and vertical
* Tabbed interface
* Optional tree view for each panel
* Built in file viewer to view files in hex, binary, text or image format
* File viewer inside archives too
* Built in archive handling: ZIP (read, write), CAB (read, write), RAR (read)
* Nested archive handling
* Built in FTP client
* Easy access to system folders, control panel, desktop and start menu
* Copy, move, delete, rename files and folders
* Multi rename tool
* Wipe files
* Create and verify MD5 checksums
* File splitting
* File properties and context menu
* Calculation of folder size
* Folder comparison / synchronization
* Modification of file date and attributes
* Folder / program favorites
* File searching (inside archive too)
* File filters for display
* User defined columns for detailed view
* DOS command line
Download from
http://www.freecommander.com/fc_downl_en.htm
* Tabbed interface
* Multi rename tool
* Wipe files
* File splitting
* DOS command line
Download from
1 REPLY 1
02-01-2009 9:47 AM
took a small amount of playing with but the wild card replace function did exactly what
I wanted with my long file name problem.
IE a list of over 30 files all starting with PocketGPS_UK_ two moves , highlight the files do a bulk rename (Ctrl M) put in the string, nothing in the replace with and Bingo done
