FF and Unresponsive script
- Re: FF and Unresponsive script
20-08-2014 2:01 PM
Today I kept getting this error on my laptop when trying to login to First:Utility.
In the end I used Task Manager to quit FF and any Java apps running, then on reopening FF I quickly closed the First:Direct tab.
I had no problem with Chrome.
Any ideas what is really the issue and how to prevent it in future?
Forum Moderator and Customer
20-08-2014 2:19 PM
20-08-2014 2:20 PM
Quote from: Mav ...I had no problem with Chrome.
Lead me not into temptation.
20-08-2014 2:38 PM
PC is out of action for a few days as the new power supply failed. But that is still on V6 but can't remember which build as the later builds tend not to work too well with JDownloader.
Don't tell me, you know the way
Quote from: ReedRichards Lead me not into temptation.
21-08-2014 8:36 AM
JavaScript is handled entirely by your web browser itself, you don't need Java installed for Firefox or Chrome to handle JavaScript. Any problems with JavaScript are likely to be due to Firefox add-ons causing problems.
Quitting any Java applications that were running on your computer, independent from Firefox, will not have any impact on what JavaScript Firefox is or isn't running.
21-08-2014 9:19 AM
That does explain why quitting Java had no effect
21-08-2014 9:25 AM
https://support.mozilla.org/en-US/kb/warning-unresponsive-script
Not sure I would want to go that route... but.....
21-08-2014 9:34 AM
Never used to happen on the PC but maybe something has changed in their site. Should be getting the PC back later today so will test that later.
21-08-2014 10:55 AM
21-08-2014 12:50 PM
21-08-2014 12:58 PM
22-08-2014 8:52 AM
22-08-2014 9:40 AM
I clicked on the download box, gave me a .exe file to save.... when trying to execute it... my laptop "froze"... the mouse cursor moved but the buttons did not function.... had to shut down with the power button..... restart "windows normally"... still the mouse buttons did not work... removed the mouse and inserted it again... managed to "restart" ( re-boot ).. and now seems to be working ok...
23-08-2014 8:07 AM
23-08-2014 10:53 PM
