FF and Reload Tab
Mav
Fixes: 515
FF and Reload Tab
FF35.0.1
Just one site seems to automatically reload its tab - haven't timed it yet - and that's the Mail on Line.
I have right-clicked and gone to Reload Tab Every and tried selecting Custom. Setting it to zero then greys out the OK button. I have also selected Disable All Tabs but still the tab reloads. It never used to happen but can't be certain if this action started since the latest version was installed.
Can a site overrule these settings to force a tab to reload?
Is this happening for anyone else?
Forum Moderator and Customer
1 REPLY 1
nanotm
Re: FF and Reload Tab
yes the ability of websites to override user settings was one of the many reasons why I stopped using FF some years back .....
