FF 6 - wont load a GIF - Solved - sort of
pierre_pierre
I am running Win 7 and have my own home page, I use a .gif file to hide the e-mail adress, it worked ok on FF5, still works on IE but wont load on FF6
the peter.gif is ok, just the email.gif wont load
<td WIDTH="30%"><a hferf="mailto:webmaster pierre.free-online.co.uk"><img SRC="email.gif" BORDER=0 height=85 width=141 align=TEXTTOP></a></td><td><img SRC="peters.gif" ></td>
</tr>
</table>
<a href="http://www.wunderground.com/global/stations/03683.html">
7 REPLIES 7
Peter_Vaughan
Re: FF 6 - wont load a GIF
There are a few funnies with that code - not sure if it's caused by you pasting it to the post but...
hferf should be href
where did the [/url] come from as that is BB code not HTML so should be removed.
In place of [/url] you need to terminate the <a> tag with </a>
so you should have
<td WIDTH="30%"><a href="mailto:webmaster pierre.free-online.co.uk"><img SRC="email.gif" BORDER=0 height=85 width=141 align=TEXTTOP></a></td><td><img SRC="peters.gif" ></td>
</tr>
</table>
See if that works.
pierre_pierre
it wasnt the whole line, and if I put in href, it didnt display.  I have been using that code for at least five years with no problem, dont know where that /url came from its not in my source code
<hr size="3" width="50%"><table BORDER=0 <tr >
<tr>
<td WIDTH="30%"><a href="mailto:webmaster peter.free-online.co.uk"><img SRC="email.gif" BORDER=0 height=85 width=141 align=TEXTTOP></a></td><td><img SRC="peters.gif" ></td>
</tr>
</table>
<img src="http://banners.wunderground.com/banner/default/global/stations/03683.gif" height=60 width=468></a>
Peter_Vaughan
The [/url] probably got added by the forum software - i've seen it get confused when you post HTML. Using the 'code' BB tags often helps.
On the first line you are missing the closing '>' for the table tag and you have an extra <tr> tag
The fact that other gif files are shown suggests the browser can show gifs fine, so there must be something funny with the HTML or the actual gif itself.
Oldjim
Resting Legend
Fixes: 63
Does for me with FF6.0.2
Note that it is an animated gif which may be the problem
Have you checked if your ad blocking software is blocking it
pierre_pierre
not worried about the extra tags, as it is only part of the code.
I have tried EMAIL.GIF and email.gif on my web space, but FF6 wont look at then - it is an animated gif, as is the peter.gif
pierre_pierre
thanks oldjim, but the peter one is also animated, strange, I am also on FF6.02,  will have to clear the cache and try again
Jim, you put my name in clear on the post
pierre_pierre
just cleared the cache, its now OK, one of those mysteries of life
