FF 28 pdf print issue
HairyMcbiker
All Star
Fixes: 21
Anybody else have this issue:
Open a pdf in the internal FF viewer, try to print it.
Print preview is fine, but all I get out is blank pages.
Save then open in ocular and it prints fine.
6 REPLIES 6
VileReynard
Fixes: 20
Re: FF 28 pdf print issue
I use an external viewer (evince) since specifying a viewer as a FF viewer means that you don't get a choice to view or save PDF files.
HairyMcbiker
All Star
Fixes: 21
You do get the automatic view than the options to save/print with the built in one. Save works but twice now I have had blank prints.
VileReynard
Fixes: 20
For me, the save/view ratio is roughly 50/50.
What is the internal FF viewer anyway?Huh
There are many viewers available.
There is even a write to PDF file printer available (via CUPS).
If you just print to file you can get a postscript file - which can be converted to pdf with ps2pdf. Smiley
PeeGee
Quote from: vilefoxdemonofdoom
I just select PDF at the print stage Wink - not had a failed print yet (and it's easier to change scaling etc. if one line prints on a second page) Roll_eyes
But, that doesn't correct the blank output from a PDF displayed within FF Cry
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
HairyMcbiker
All Star
Fixes: 21
Its the viewer for pdf's that was introduced a while back.
80% of the time I just want to view the pdf to check something, so it is faster to do so in the browser. If I want to I can then save it.
HairyMcbiker
All Star
Fixes: 21
Looks like it is fixed in the latest version:
29.0.1 - pdf.js printing white page (1003707)
Just got to wait for it to be released.
