FF 28 pdf print issue
- Re: FF 28 pdf print issue
06-06-2014 2:10 PM
Anybody else have this issue:
Open a pdf in the internal FF viewer, try to print it.
Print preview is fine, but all I get out is blank pages.
Save then open in ocular and it prints fine.
6 REPLIES 6
08-06-2014 1:02 AM
I use an external viewer (evince) since specifying a viewer as a FF viewer means that you don't get a choice to view or save PDF files.
08-06-2014 10:16 AM
You do get the automatic view than the options to save/print with the built in one. Save works but twice now I have had blank prints.
08-06-2014 12:09 PM
For me, the save/view ratio is roughly 50/50.
What is the internal FF viewer anyway?
There are many viewers available.
There is even a write to PDF file printer available (via CUPS).
If you just print to file you can get a postscript file - which can be converted to pdf with ps2pdf.
08-06-2014 12:28 PM
Quote from: vilefoxdemonofdoom If you just print to file you can get a postscript file - which can be converted to pdf with ps2pdf.
I just select PDF at the print stage - not had a failed print yet (and it's easier to change scaling etc. if one line prints on a second page)
But, that doesn't correct the blank output from a PDF displayed within FF
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
08-06-2014 12:28 PM
Its the viewer for pdf's that was introduced a while back.
80% of the time I just want to view the pdf to check something, so it is faster to do so in the browser. If I want to I can then save it.
08-06-2014 12:32 PM
Looks like it is fixed in the latest version:
Just got to wait for it to be released.
Quote 29.0.1 - pdf.js printing white page (1003707)
