F-Secure email to Linux Customers
- F-Secure email to Linux Customers
03-08-2010 11:17 AM
Just dropped into my Inbox.
Quote Dear F-Secure Partner or Customer
We have a case which affects all Linux products with AVP engines, both standard and extended. Those are:
· Linux Security 7.x (full or "command-line-only" installation)
· Internet Gatekeeper for Linux 3.x
· Corporate Suite
The problem symptoms are engine crashes caused by a certain type of malware, of which the product recovers immediately, but which creates a large crash dump file each time. With several crashes per minute the amount of dumps will start filling the hard drives, which can lead to a complete system failure.
2 REPLIES 2
Re: F-Secure email to Linux Customers
03-08-2010 4:04 PM
Why run it at all?
I think you might need a super-computer to run this on.
Quote Important
F-Secure will release an AVP-database update on August 5th 2010, 03:00 AM EEST. This update will again trigger the issue described in this article, unless the AVP-engine version has been updated with the relevant updates linked to this article.
Memory consumption
Note: with the updated AVP engine in place, memory-consumption at engine startup is about 150 Mb higher compared with the previous AVP-engine build. After the engine has started, the new AVP engine consumes about 40 Mb more memory.
03-08-2010 5:02 PM
Quote from: A Why run it at all?
Fortunately we don't
