External hard drive
Minivanman
Legend
External hard drive
Flying by the seat of my pants I have never bothered to back up anything on my computer.
Not wanting to waste money on the wrong, unnecessary or overpriced product can anybody recommend a half decent and reliable external hard drive - as they seem the best option.
Cheers as always guys Thumbs_Up
Truth is like a threshing machine; tender sensibilities must keep out of the way.
Herman Melville
13 REPLIES 13
Darkfire
Fixes: 30
Re: External hard drive
I have a Seagate Backup Slim 1TB that i use as a fix everything drive and for quick backup device when working on computers for people, anything along those lines should work great, get one that is powered by the USB though, no need to mess around with extra power connections that way.
I can't knock it at all even with Seagates not so stellar reviews of harddrive life, I've had it 2 years without a single issue.
DS
Seasoned Champion
Fixes: 22
Got any old PVR's kicking about?
You could always rob one out of that, pop on to an internet auction site and pick up a very cheap usb to HDD lead, possible a caddy/housing too...
I wouldn't put an operating system on one, as PVR HDD's are different to a PC/Laptop HDD, but they can be used for almost anything, I'd go down down this route if it was me;)
(and most basic PVR's start at 160GB up to 500GB)
Minivanman
Legend
Thanks guys, just spotted this on a Tesco site, but will it work with my Windows 10? I suspect it will but just a bit unsure.
http://www.tesco.com/direct/toshiba-1tb-usb-30-external-hard-drive-black/363-2371.prd?skuId=363-2371
Herman Melville
DS
Seasoned Champion
Fixes: 22
Although it states W7 and W8, I'm pretty sure it'll be fine;)
VileReynard
Fixes: 20
I reformatted one to a Linux file system and it works on USB2 or USB3.
It's only a disk on the end of a USB cable - mine was a Seagate unit.
It can receive sufficient power from USB3, but for USB2 a separate mains brick is preferable.
Are cable(s) supplied?
Minivanman
Legend
I've been puzzling over that USB2 and USB3, what's the difference?
Herman Melville
SpendLessTime
Fixes: 86
USB3 is faster but it is backward compatible with USB2 and USB1.
The USB3 sockets in computers are identical in appearance except for the code of the plastic tab inside which is normally blue.
VileReynard
Fixes: 20
Speed.
USB2 480Mbits/sec
USB3 3Gbits/sec
Of course it doesn't go faster than the disk inside.
NorthPole
Fixes: 6
I did find though that putting a SATA disk drive recovered from an old laptop into a disk caddy supposedly suitable for USB3 resulted in numerous R/W errors when it was plugged into a USB3 socket on the PC. Worked fine however on the USB2 socket. I assume the data throughput on the USB3 socket was too fast for the disk firmware.
DaveyH
Champion
Fixes: 12
A single backup copy isn't really a backup, especially if it's kept on-site with your computer
JayG
Fixes: 6
Can't speak for other OS's, but on Win7 I create system images using the built-in utility, and also do back-ups using Comodo - never had to use any backup yet, but it seems to make sense to have more than one type using different utilities in case one won't restore. Don't forget to make a recovery disc too to enable you to boot up your PC if the OS fails completely.
(I used to make additional backup copies of my 'personal' folder using Windows Explorer to drag and drop multiple folders to the external HDD, but for some months I've only been able to copy one folder at a time and I have yet to find out why.)
ReedRichards
Seasoned Pro
Fixes: 25
What volume of data do you need to back-up?  1TB might be overkill if you don't have a lot of photos, videos or music.
VileReynard
Fixes: 20
The difference in price between a small (500GB) and medium (1TB) is not great.
2TB or 3TB are rather expensive though (£100+).
