External Usb drive
paulgul
External Usb drive
Has anyone ever took one of these apart, I assume they contain a standard drive but is it hard wired or are the connections just plugged in as an internal drive? My reason for asking, I have 2 of them at the moment but was thinking of buying a esata drive docking station and was wondering if I could use the drives from the usb devices with the resulting increase in transfer speed.
Any thoughts?
Paul
Re: External Usb drive
They vary, and the drives may be IDE or SATA, but generally the ones I've taken apart deliver a fairly standard drive.
However, not all are formatted in a standard way so once dismantled the existing data may be inaccessible and you may need to reformat (NTFS or FAT32 probably) to reuse.
paulgul
Ahh, I hadn't thought about formatting, just assumed they would be readable. I suspect they may be sata drives, both fairly new 1TB drives.
Fixes: 19
They all use standard hard drives and as standard hard drives are made for plug-in connections, there is no hard wiring.  Non-standard formatting is news to me, perhaps HPsauce will elucidate?
I've seen many external drives recently that use proprietary formats driven by the specific manufacturers software and backup utilities.
Can't recall the last brand, but it was one of the big names. No hope of getting data off once the interface electronics and software were removed without using expert technical knowledge; certainly not a windows-recognised format.
paulgul
In my case both external drives are for backups so I won't worry about re-formating and creating new backups
VileReynard
Seasoned Pro
Fixes: 9
My NAS drive allowed me to use FAT32, NTFS or ext3
So it's ext3 Grin
Quote from: A
ext3
Which, as I'm sure amuses you immensely, Windows does not recognise without added drivers.  Roll eyes
It could well be that the external drives I described as "proprietary" were using such a format, but as they were sold mainly for use on Windows systems that is maybe not 100% sensible.
VileReynard
Seasoned Pro
Fixes: 9
Works fine.
Windows or Linux.
If it fails, it's likely to be the hard disk - in which case I can just throw the disk away.
