External USB TV card for Laptop
- External USB TV card for Laptop
05-10-2011 8:42 PM
Must be under £40. (got my birthday money to spend ! ! )...
do I need to buy an aerial? If so, any recommendations..... ? It would need to be small(ish) to be able to transport it with the laptop, yet good enough for medium strength signals..
Any helpful advice/information would be useful
Re: External USB TV card for Laptop
05-10-2011 8:56 PM
I bet there's a lot of less scrupulous sellers out there still trying to offload analogue tuners which will no longer work in many areas and soon will not work anywhere in the UK.
Many come with an 'Aerial' bit it's like a small knitting needle on a little stand, if your signal is good enough for a preper TV to get decent reception using a knitting needle then this will suffice, otherwise you pretty much need some sort of additional aerial, beware some USB tuners use a miniature coaxial aeriel connector and may not always provide an adaptor for a proper aerial plug.
05-10-2011 9:00 PM
Any more gems around?
05-10-2011 10:37 PM
I'm in a poor reception area so have to use a booster and its off the main aerial not an indoor.
05-10-2011 11:50 PM
06-10-2011 8:34 AM
will only be using it occasionally, so hopefully wont be a big problem...
Yes, I do have a TV licence,,... so again... no problem
09-10-2011 9:34 PM
can`t get a signal on the little aerial supplied, despite being less than 25 miles from the Rowridge, I.o.W. transmitter....
will give it a go when out in the car, and see what happens...
09-10-2011 9:42 PM
Quote from: Peter One thing to be aware of... the need for a TV licence. If you have a TV licence for your home that's fine as it will cover out of home usage...
...so long as the out-of-home device is running on battery power.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
09-10-2011 10:11 PM
Quote from: shutter can`t get a signal on the little aerial supplied, despite being less than 25 miles from the Rowridge, I.o.W. transmitter....
'knitting needle' - told ya so!
Best bet really is to invest in a 'boosted settop aerial' with a 12V input (ones sold for caravans are ideal), youl'll get the best chance of a decent signal short of finfing a proper aerial wherever you are.
10-10-2011 8:31 AM
Thanks for the suggestion on the boosted 12v aerial ..... something else to carry around in the boot ! ! ...
cheers guys
