External Hard Drive now showing as not initialized
neepdocker
Switched on my external back up drive to find it did not show up in 'my computer' explorer etc. It appears in computer management - disk management as Disk 4 with a little red 'no entrysign' unknown and not initialized also unallocated. Can I recover entry to this disk and can my important back ups be retrieved. If so How  ...........help
Re: External Hard Drive now showing as not initialized
Have you tried anything at all to rectify it?
If not try the simplest first...
Assuming it's a USB connection, unplug the device, reboot your PC then reconnect the device. There's no real reason why your files should be wiped, it's your PC not seeing the device, not the contents of the drive.
neepdocker
Tried all basics and also connected it up to my second computer with the same results. On checking out other forums found the suggestion to right click on the Drive  in device manager which allowed me to initialize the disk and removed the 'no entry' sign. I hope this has not been the wrong thing to do. I am still left with the disk unallocated and after a cold reboot still not showing the drive in my computer... so might or might not be a step in the right direction. Any ideas on how to access the data on the Drive.
You need to see if its the drive or the interface thats faulty.
You will have to open the case and plug the drive into you pc and see if its ok then. If it is then there is something wrong with the cable or interface.
If the pc cant see it then its the drive dont forget to set it to slave/master correctly when you put it in your pc
