External HDD Recommendation
- External HDD Recommendation
02-08-2015 8:06 PM
Do youse have any recommendations as to brand and/or model I could look to as a replacement? I don't really want one bigger than 1TB, because the bigger the drive, the more faff it is when it finally fails (but I had at least 95% of the data on this one backed up to CD-R or DVD-R, so it's more an inconvenience than a catastrophe). And I'm not yet convinced enough of the reliability of SSDs to go down that route.
TIA
Re: External HDD Recommendation
02-08-2015 9:03 PM
02-08-2015 9:37 PM
Besides which, I don't see the point. The data is on the disc rather than anywhere else inside there. Might as well get a new drive altogether.
03-08-2015 2:37 AM
03-08-2015 8:22 PM
09-08-2015 9:15 PM
10-08-2015 12:37 AM
I've got a 2TB version of your Seagate, which has been reliable for 18 months and counting...
11-08-2015 9:33 AM
of course as I mentioned you can disable the drive's eco feature which defeats this cycle to some extent and you can similarly disable the usb selective suspend feature in windows power saving and stop it sending out the check messages which similarly stops the pc from effectively seizing up
not much help to you in this case but useful for the future perhaps
11-08-2015 11:25 AM
It also comes with an external power supply, so I can use it on USB 2 connections too.
11-08-2015 11:36 AM
Quote from: thejudge There don't seem to be any screw-holes in it ...
If there are little rubber feet on it, the screws are likely under the rubber feet, so peel them off and have a look.
3Mb FTTC
