Explorer windows set to 'On-Top'
Mav
Fixes: 515
Suddenly two out of the Explorer Windows I have opened appear to be set to 'Always on top' - win W7 Pro 64.
A Google search suggests that it may be a bug in W7 and various solutions range from quitting Explorer from Task Manager (drastic as I have quite few open in positions just as I like between the two monitors) to attempting to make all windows the same  Roll_eyes
The consensus seems to be that the bug can appear after 'Show Desktop button' is clicked which I did do earlier. But it doesn't always cause this. I have tried clicking the Show Desktop button again a couple of times but it hasn't rectified the issue.
Has anyone else seen this problem and resolved it as I cannot find any reference in any Explorer settings to a 'Set window to top' option?
Forum Moderator and Customer
