Exchange Server linux alternative
- Exchange Server linux alternative
17-02-2008 3:14 AM
Simple reason being I am trying to save some money (and headaches with AD and 2k3!!!)
Anybody any ideas of alternates? Cheap - Free if possible!
Scott
Scott
5 REPLIES 5
Re: Exchange Server linux alternative
17-02-2008 10:56 PM
A quick google shows loads of mail servers for Linux. What you need to specify is what you want it to do ie how many users, will it need to connect to windows AD, do you want webmail etc.
If you give the full specs then some of the Linux boys can suggest something. What spec of PC will it be running on and have you expertize in Linux to configure the server
17-02-2008 11:51 PM
heh, well, id looked at using postfix, mysql, clam av and spam assasin on the server, server is an HP Proliant ML110 G5 system, os is currently fedora 8, but open for change.
18-02-2008 12:01 AM
That does not say what the current email users actually use within outlook; calendar, local contacts list, global contacts, shared folders, TODO, multiple folders, some users being able to access and/or send on behalf of someone else.
Do you have mail delivered direct to your server via SMTP or do you have a POP3 connector process to pick up POP3 mail or both?
You need to ensure whatever replaces exchange can be backed up and more importantly can easily be restored on an overall basis or individual mailboxes.
Do you need webmail?
Do you need to import existing mail and contacts (address book) to the new system?
Do you have a lot of Unix experience as maintaining a mail system may well take longer than an inequivalent MS product.
18-02-2008 12:15 AM
That does not say what the current email users actually use within outlook; calendar, local contacts list, global contacts, shared folders, TODO, multiple folders, some users being able to access and/or send on behalf of someone else. - Currently, I use the calendar.. but not a lot.. the same for all users.
Do you have mail delivered direct to your server via SMTP or do you have a POP3 connector process to pick up POP3 mail or both? smtp delivery
You need to ensure whatever replaces exchange can be backed up and more importantly can easily be restored on an overall basis or individual mailboxes. - if possible
Do you need webmail? - no, but would be useful
Do you need to import existing mail and contacts (address book) to the new system? no
Do you have a lot of Unix experience as maintaining a mail system may well take longer than an inequivalent MS product. - a reasonable amount, not with postfix or exim etc, more with other net services on the system.. i had looked, and would happily use MS exchange, if only i didnt need to use damn AD to make it work!
18-02-2008 11:32 PM
anbody any thoughts on Zimbra, looks like a good solution?
