Excel ...Exact function gives "False" result.... puzzle
Luzern
Seasoned Pro
I tried to compare two text strings to see they are the same. They have the same cell format, font style, size, and colour, yet the result of comparison is "False",
Am I misunderstanding the "Exact" function?
Fixes: 62
Re: Excel ...Exact function gives "False" result.... puzzle
You aren't.
I just did a quick check and adding a trailing blank to one of the text strings makes the answer false - might be worth checking
Luzern
Seasoned Pro
You were right! Smiley LEN function gives 14 and 9, but how does one remove trailing blanks , they being invisible? Undecided
Fixes: 62
put the cursor at the end of the text and press backspace  Grin
unless you mean remove trailing blanks automatically then use this function
http://www.techonthenet.com/excel/formulas/trim.php
Luzern
Seasoned Pro
Very helpful indeed! Smiley
